Apartment building electric service
ammklq143
Iowa
I have a customer asking about an estimate for a building he would like to convert to apartments. There would be 6 meters/disconnects for the apartments and each apartment would have a 100 amp panel. There would also be 1 meter/disconnect for the common area for a total of 7 meter/disconnects. I've not done an apartment of more than three so I'm curious how others would build the electrical service with the meters and disconnects. I haven't found a ganged meter socket with more than six sockets so would I be able to use a six gang socket and then feed out of that to a single for the common or.....? Any suggestions would be appreciated.
Thank you.
Thank you.
No. You would be over the six disconnect rule for service disconnects. NEC 230.71(A) You would need a main disconnect ahead of the meter stack.
