Dogbonedog
- Kansas
- Electrician
I have stumbled into an apartment complex with 40 meters/100A 240V breakers with feeders headed to each apartment 100A apartment panel. In the room there are three “main disconnect” switches that divide and shut off 10-20 meters. We are swapping the old house panel out but bonding with the EGC happened in this panel and no ground wire pulled into “main disconnect” where I’m sure the utility is entering (There is a meters between the house panel and “main disconnect”) that disconnect the bonding happens to all GEs with 600A Fuses. Also none of the feeder( to individual apartments) ground wire goes there. Is this a utility (meter) disconnect or a service disconnect? Can I bond in my new 200A house panel and use neutral back to “main disconnect”? Thanks
