Lock the door.
The prints show the panel mounted behind the front door. I've checked the code and can't find anything. It seems to be a safety issue. Suppose your working on the panel and someone opens the door. Thanks.
A rubber handled screw drive makes an excellent door stop if you can't lock the door as was suggested.
That aside behind the door is perfect in a apartment because no furniture will ever be put there.
I like the "behind the door" location and use it often in my designs, for this very reason.That aside behind the door is perfect in a apartment because no furniture will ever be put there.
