Re: Apparent Power, KVA?
It?s more complicated than that. But here?s a general set of rules. It uses as an example, an electric generator. But the rules apply to other components also.
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">The KVA rating is based on the ability of the generator windings and the surrounding components to dissipate the heat that will be created within the windings.</font>
<font size="2" face="Verdana, Helvetica, sans-serif"></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">The KW rating is based on the capabilities of the prime mover (e.g., the diesel engine, the gas turbine, the water turbine: whatever is providing the motive force to spin the generator).</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">The voltage rating is based on the ability of the insulation system to prevent leakage current from the windings to the outside world.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">The current rating is based on the cross-sectional area of the conductor used to construct the windings.</font>
<font size="2" face="Verdana, Helvetica, sans-serif">In a transformer, copper loss is indeed a function of the current. You will have voltage drop, and therefore energy losses, as current flows through any conductor. That is true for a straight run of wire; it is true for wire that is wound in circles (i.e., transformer windings).
Iron loss occurs because the windings are wound around an iron core. This helps to conduct the magnetic field from the primary windings to the secondary windings, and to concentrate its intensity. As the AC current flows back and forth, the iron is magnetized first one in direction, and then in the other. That is the reason for the loss of energy. But the magnetic field is created by the flow of current. Its strength is determined by the amount of amps and the number of times the wire is wound around the core. Voltage has nothing to do with this equation.
