Re: appliance brance circuits
210.23 Permissible Loads.
(A)(2) Permits the multiple loads to not exceed 50% of the branch circuit rating.
I have seen the dishwasher and the disposal range in size. If you know the ratings of the equipment before you pull the circuits, you can determine if you need two circuits, if you do not know the ratings, you may be better off running two circuits.
Why would a two pole breaker be required?
... Or you can follow 210.19 (A)(4) exception No. 1. Run a 30 amp circuit and tap them under the sink.
Pierre
[ October 21, 2003, 02:16 AM: Message edited by: pierre ]
