dnbob
- Rochester, MN
Are you required to install a receptacle in a kitchen appliance garage? Or can that area be considered a break in the countertop?
How would this be accomplished, just by putting the appliance receptacle on a switch/indicator light combo. to be installed on the outside of the appliance garage? Or does the switch actually have to be intrinsically tied into the door so as to automatically disconnect power when the door closes?Originally posted by bill addiss:
...Canada has an interesting rule regarding Receptacles inside Appliances Garages that requires the power to the outlet be switched off if the 'Garage' door is closed.
Bill is correct, the relevant paragraphs read as follows-Can any of our Canadian members confirm or deny this?
About ten years. I think someone probably folded up the built-in ironing board with the iron still plugged in.How long has this been in effect?
I agree with you Tom, that is why I asked the question in another thread... here.Originally posted by tom baker:
...You can look at it two ways...
