If you have a motor operated or refrigeration appliance and the cut sheet does NOT indicate circuit breaker requirements, then what can be done in the following example:
Let's say you have a refrigerator that draws 1.2 amps:
1) Are you required to put this on a 15A breaker?
2) What rules to follow if connecting multiple units on the same circuit? Can I put three on? Five? What's the limit?
