The company I work for builds control panels for industrial equipment. All panels are a part of the equipment and are fully tested prior to shipping. Voltage, running current, and locked rotor inrush current readings are taken on all motor loads on the load side of the starter, contactor, or VFD. Panel supply ratings range from 15 to over 250A, with motor sizes from 1 to 300HP. Voltages range from 208 to 480 3-phase.
The boss says 70E "stuff" does not apply to the work we do because it isn't maintenance work, and then argues that there has never been a need for it in the past.
Where can I find information that mentions or references OEM facilities and work practices that I can show to the boss?
