switchleg45
- Ft Myers,FL
Question: What would be an approved method of testing an installed and operational switch for proper grounding?
Would..say..a cord plugged into another 120V non-GFI receptacle to supply a 120V potential (hot side) to a load (wiggy or lamp socket?) and then test your plate screw heads for your 'return' path to test for ground be "approved"?...or is there an approved ground tester for this application for inspectors use?
