jmullinselec
- louisville
- electrician
i am having a crazy issue that is beyond my expertise.
i have a square d qo panel in a home with arc fault gfci breakers installed (newer home) i was contracted to do wiring for a pool
off the main panel i installed a sub panel about 40ft away siemans type 125 amp 8 space outdoor mai lug panel in this panel there is a 2 pole 50 (heat pump) 2 pole 20 gfci (variable speed hayward pump) and a single pole 20 (gfci, salt chlorinator, and lights). at times wen the heat pump kicks off it trips the gfxi arc comb breakers in the house, also noticed with heat pump off and pump on the breakers in the arc gfci breakers in the main panel are warm my question is could the harmonics from the variable speed be messing with the qo breakers none of my breakers in my sub panel have never tripped i have pulled my hair out over this any insight would help ( i have also checked all bonding in house and my panel )
