This question was asked of me and I need a little help with it.
There is an existing basement with an unfinished room that is going to be converted to a bedroom. All the alterations have been made so this room can be done by building code. There is an existing circuit to be used and an arc fault breaker to be added to feed this bedroom circuit. The question is :Can I use this circuit for the rest of the basement area that is not finished by adding a GFCI Outlet to protect the outlets that is required to be GFCI protected? If this is done how will the Arc fault and GFCI react to each other?
