...and what State as wellWelcome to the forum
The AFCI rules keep changing so it would help if you said which year NEC you work under.
OK I got it NJ does not use AFCIs
One day that will change and you will be all messed up.![]()
Just to ease my mind. Does the circuit for a light on the outside of a home have to be arc fault protected if the switch for that light is in the bedroom?
2005 NEC
Bryan, Texas
This was discussed at length in a thread last year. I don't think there was ever any consensus about whether or not a switch constituted and outlet.
On a related note,and by way of expanding my horizons...
I am guessing there is a code section about not wiring residential lighting outlets on 30amp circuits. Am I correct, and what section would I find this in.
the thought has occurred, yes:grin:HA. Talk about desperately not wanting to use a AFCI
Probably not practical due to cost of wire and switches, but wondering if some rich idiot wanted it, could it be done and meet code :grin:
That question resulted in the longest thread this Forum has (781 posts). A poll was done near the end of it. Of those that voted, the tally was three to one in favor of switches not needing AFCI protection.Just to ease my mind. Does the circuit for a light on the outside of a home have to be arc fault protected if the switch for that light is in the bedroom?
2005 NEC
Bryan, Texas
Thanks for the code ref.Typical home appliances will not plug into a 30 amp receptacle and you can not supply either 15 or 20 amp receptacles with 30 amps. See 210.21(B)(3)
I also checked out 210.23(B) and table 210.24. I believe this effectively rules out the 30amp to avoid AFCI in all dwelling bedrooms. Would that be correct?
I held the minority opinion that a switch must be AFCI protected when in an area that 210.12(B) applys.
A switch IS NOT an outlet.
FRom article 100 Definitions
Outlet- A point on the wiring system at which current is TAKEN to supply utilization equipment.
A switch does not take current to supply utilization equipment. A switch controls the flow of current
