Riograndeelectric
- Lakewood Colorado
Ok so when both the Electrical are manufactures SQ D, Siemens. Cutler hammer & GE and the appliance manufactures going to get tighter and ensure that when we install arc fault breakers as required that the appliances are not going to start nuisance tripping the breakers.
I have a customer who runs a business out of his basement and just expanded the basement to finish off more space. I installed all new arc fault circuits.
The customer has a high end Konica Minolta color copier, net work printer and fax. The copier specs called out for a dedicated 20-amp circuit. the customer yesterday had the copier delivered and plugged it in and with 5 minutes the breaker tripped this was when the copier is not being used just at an idle.
Therefore, when are both sides going to get together and make a good appliance that does not send a distortion along the circuit or have a high current leakage?
I hate telling the customer that the breaker is doing its job and function properly and that it is the equipments fault.
