chicago-tony
Is there a problem with double 15 amp branch circuit breaker that culter hammer makes. Evertime the inspector test (trips) the receptacles. The inspector goes into the basement to re-set the breakers and the re-set is always stuck (yellow). Whats the problem??? Defect? Does anyone know what arc-fault breaker is trouble free? I know that hammer has a warranty issue if I were to used a different kind I breaker (maker)
