vilasman said:It has been my expierence that you cannot put a light fixture on a circuit that has a arc fault breaker on it, is this correct?
The work should have been done to the NEC cycle being enforced at the time of the original permit approvals. Unless newer peremits were issued, the AFCI's should not have been required.vilasman said:Well my first expierence with arc fault breakers was while I was finishing a new house job, that 3 other groups of electricians had worked on, in PG county, Md, that had been started 5 years ago now, before arc faults were required, and I failed inspection, for the lack of arc faults and was getting re inspected the next day.![]()
hockeyoligist2 said:Are AFCI's required on the bedroom light's? Which article in 2005?
77401 said:We better get practice with this cuz the '08 NEC 210.12B is requiring AFCI everywhere in dwellings.
