mickeyrench
- edison, n.j.
Does anyone know if new jersey is inforcing the use of afci breakers ? The code was suppose to change in 2008.
mickeyrench said:Does anyone know if new jersey is inforcing the use of afci breakers ? The code was suppose to change in 2008.
I can't see how?2005 NEC said:210.12(B)(2)
Branch/feeder AFCIs shall be permitted to be used to meet the requirements of 210.12(B) until January 1, 2008
http://www.nema.org/stds/fieldreps/codealerts/20060505nj.cfmThe New Jersey Department of Community Affairs, Division Of Codes and Standards adopted the 2005 NEC with 20 amendments, effective May 1, 2006. The amendments are as follows:
3. Chapter 2 of the electrical subcode, entitled "Wiring and Protection," is amended as follows:
i. Section 210.12(B) of Article 210, entitled "Branch Circuits," is amended to insert the following sentence at the end of the section, "This requirement shall be considered optional."
Jerseydaze said:This is my first code change in my own business in Jersey when does the new code get adopted and how will I know thanks
celtic said:Your CEU's must be completed by March 2009
I think that leaves some of youse - and youse know who youse are - plenty of time to get the CEU's out of the way.
If you check the [State Board of Examiners of Electrical Contractors Minutes Page]...seems every code cycle someone gets caught with thier pants down.
When in doubt CALL the Board ~ (973) 504-6410.
I wasn't sure when these had to completed by...so I called
10 hours?infinity said:This allows everyone to take the required 10 hour code update classes before the code goes into effect.
Jerseydaze said:Does every state operate like this im sure a lot of guys don't realize this . the supply house is already pushing the florescent fixture disconnects which according to you wont be enforced for over a year.
celtic said:10 hours?
I thought 34 (10 +24 "electives")were required now???
Each State operates as they wish...while it is a "National" Electrical Code, it has not been unilaterally accepted as the Code is published...ie, The NFPA released the '08 in Sept (+/-) of 2007...some States accepted it 1/08...NJ will probably accept it in 3/09...others are STILL using '02 and even EARLIER editons....while some States ~ when leaving this task up to individual counties and/or municipalities ~ may have never accepted it.Jerseydaze said:Does every state operate like this im sure a lot of guys don't realize this .
The supply house is the business of selling :grin: ...the manufac.s are ultimately the ones pushing the supply house :wink: and everyones happy :-? (LOL)Jerseydaze said:The supply house is already pushing the florescent fixture disconnects which according to you wont be enforced for over a year.
That would be ALL...not some.satcom said:And some cities, and towns in Jersey may not have the codes into law until 2010 it all depends on how long it takes to get it into law.
satcom said:Yup 34 hours, even a doctor only needs 12 hours, guess they think electricians are really thick!
celtic said:That would be ALL...not some.
Correct?
infinity said:You're correct. NJ has a state wide adoption. There are no local electrical codes.
And yes, it is 34 hours, but I was speaking about the 10 hours that pertain to the new code changes.
