c-pwhitson
I have a 100 amp sub panel in garage.Garage plugs are on a dedicated circuit.There are two lighting circuits that serve an addition off this sub panel.When there is a large load like a chop saw or vacume plugged in to the garage plugs it trips both arc faults.The arc faults and garage breaker are all on the same phase.What is causing this? Could there be an existing plug on the same phase as garage and arc faults that has a nuetral and ground touching?I have checked for loose nuetrals every where.I also have another arc fault on a different phase that trips when another large load is plugged in.It doesn't trip right away.I think this might have something to do with the other problem.If I had a nuetral toughing a ground it would trip instant,this is not happening.Also a small load will not trip this either.
