Duncan8943
- Lexington
I am doing an assisted living unit which is classified as R-4. If I run everything in MC cable from the panelboard, do I need to protect this circuit with an arc fault breaker? The code allows for an arc fault receptacle at the first box if MC cable is ran from the panelboard. One would think that if the entire circuit is MC cable then AFCI would not be necessary.
