Louisvillesparky
New member
- Louisville, KY
A customer purchased a gas stovetop with an auto-igniter. It is plugged into a receptacle on the circuit with the exhaust hood. These are the only 2 devices on the circuit. The arc fault breaker trips when the auto-igniter is used. I'm assuming the spark from the igniter is being detected as an arc fault. I see no exception in the code that would allow a non-arc fault breaker to be installed on this circuit. What is the best code compliant remedy for this.
