I understand that when a breaker, switch, MCC section ect. has had an Arc Flash Survey, that if it is then labeled "dangerous" that this means you are never to get in it energized. That you aren't even able to open the doors on the equipment because no amount of PPE can protect you from the blast. With that being said my question is if on an MCC section (480 volt) with the breaker door closed on one of these labeled "Dangerous", if an arc fault explosion happened while energizing the breaker would the closed breaker door protect an individual? I've seen doors blown off from these explosions. We have this situation and the instructions are for only electrical personnel to close in the breakers with PPE on. My concern is that if the blast can kill me I don't want to do it! I understand that a barrier helps with the arc flash but what about the blast energy?
