chicago-tony
1999 nec. Can you have the bathroom fixtures and exhaust fan protected by arc-fault? Example (master bedroom receptacles and master bathroom fixtures (over the basin) and exhaust fan on the same branch circuit. When the inspecter tested the master bedroom with an arc-fault tester the receptacles in the masterbedroom and the fixtues over the basin and exhaust fan trip in the masterbathroom. He told us that the lights over the basin must remain on. Note there is a 20 amp branch circuit to supply the bathroom receptacles. Is there any where in the 1999 nec that states the fixtures over the basin must remain on and a bedroom that is proteced by arc-fault can't have fixtures (bathroom,hall fixtures ect.) on the same branch circuit that is protected by arc-fault.
