Mr sparky
- Atlanta, Ga,USA
Got a garage I have four fluorescent lights which work when I turn the switch on. The problem is that when I press the test button on the arc fault breaker or manually turn the breaker off then try to reset it, it will not set unless I turn the switch off that controls the garage lights. Once the switch is off I can reset the arc fault. I can then turn the garage lights on and everything works. Why will the arc fault breaker not reset when turned off unless the switch to the garage ligbts is off? I have replaced the breaker, checked the switches and connections, even removed all the grounding wires from the fixtures and the problem persists. Once again the problem is that the breaker will not reset with the switch in the on position but when off the breaker will set and the switch can be turned on and everything works.
