What Code are you on?
-Hal
Must I use arc falt protection for all kitchen outlets. other then range ?
The state adoption in Illinois is 2008, but that only applies where a local unit of government has not adopted an electrical code. There are codes in effect from 1996 through 2017 in Illinois. You need to find out what code the area you are working in is using.2014 code. in IL.
