A problem given to me by anothr inspector.He recently encountered a problem with an arc fault that wouldn't hold. The project was a remodel due to a fire, but basically the house was completely rewired. The has tried several other breakers, but they also trip when even a minimal load (radio) is introduced. I understand from the wholesaler that they are so senitive that even an insulated staple will cause the breaker to trip if the staple is to tight.Is that a common occurrence? Are other inspectors requiring that a load be put on the circuit to test the arc fault breakers before covering the walls. What can you advise me to help this other inspector.
