ish1284
- Arlington Heights, IL, USA
Hi All,
IEEE1584 2002 implies that motor contribution for motors <50HP can be excluded from arch flash calculations. IEEE1584 implies something similar but takes out "<50HP" and rather says "small motors".
The debate I'm having is on why small motor contributions can be excluded.
I thought somewhere I saw that small motors can be excluded because their inertia just isn't enough to sustain an arc for more than 0.5 cycles. However, I can't find the reference where I thought I read/heard this. If this is the true reason why, it would lead me to believe that a lumped group of small motors that totals >50HP wouldn't need to be included in the arc flash calculations as well.
This leads to the question, if there is a group of motors smaller than 50HP that adds up to more than 50HP, should the lumped contribution be counted? If it's related to motor inertia, I'm inclined to say no because it is dependent on the individual motor size rather than what the lumped motor total HP is.
Note that I'm referring to arc flash calculations only. I understand per the ANSI standards, any size LV motor should be included in short circuit calculations. For the sake of this topic, let's stay in the low voltage realm (i.e. 480V).
