nayjay67
New member
- Lowell, Arkansas
When calculating the arc flash hazard at a sub panel (has two CBs between it and the Xformer), is the bolted fault current still set using the transformer rating, or is it adjusted due the upstream circuit breakers? Also, when considering the clearing time, with CBs in series, would you use the shortest or longest? Thanks.
