Does anyone know if Arc Flash calculations are required per NFPA 70e? I am being told that is had to be done per code?? I cant find where it says it is required. Please advise.
Also has OSHA adopted the NFPA 70e and if so does it mandate 70e compliance? Can the owner be cited if it does not comply?
I know there will not be any easy answers but anything info to put in the right direction will be very helpful.
Thank you in advance.
