1.5 pounds of tnt
1.5 pounds of tnt
Without going into the calculations it may still be in the ballpark because they didn't say the energy from the different sources was released in the same time.
Some say a lightning bolt contains 10^9 joules of energy. If you could release it over 1-1/2 weeks it would give you 1 kW for this time duration.
Also, the same amount of energy, 45 foot-pounds, is contained in a handshake, a 45 cal. pistol bullet and a fatal dose of radiation.
I guess the duration of an explosion is a few milliseconds. I read once that some kind of high explosive, strung out in a thin line, burns at 18 miles/sec.
Heathkit used to make some gadget that detects a gasoline fume explosion in progress and fills your yacht with fire-suppressant foam within 5 milliseconds.
Speaking of explosions, I always wondered what the difference was between an explosion and rapid burning.
A guy who designed nuclear weapons for a living back in the 50's told me that rapid burning has a high but constant burning rate but an explosion has a burning rate that increases with time.
If an engine knock meets this last standard, it really is an explosion in the cylinder.
