Re: Arc Flash Hazard Label
Originally posted by ryan_618: Oh, and by the way...Does having it "factory" applied make it less safe?
As you well know, the factory is not going to know the details of the installed configuration, so they can't tell what label to affix. But then, neither does the designer, for the selection of equipment comes after the construction bid is won by a contractor. For that matter, the installer cannot know exactly how the system will be operated (e.g., which large motors will be running at any given point in time), and certainly would not know if the utility were to have made a significant change to the transmission and distribution system parameters after the design drawings had been issued. Therefore the installer cannot tell what amount of arc fault current will be available at the panel. In fact, any number of changed conditions will impact the requirements for PPE.
Therefore, the only thing that is reasonable, which is to say, "reasonably accurate," is for the technician who is about to work on the panel to do the following:
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Ascertain all facts about the installed configuration,</font>
<font size="2" face="Verdana, Helvetica, sans-serif"></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Ascertain all facts about the operational conditions,</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Obtain the applicable system parameters from the utility,</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Perform a calculation,</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Determine the appropriate label,</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Affix the label,</font>
<font size="2" face="Verdana, Helvetica, sans-serif">AND THEN:
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Read the label to learn what PPE to use.</font>
<font size="2" face="Verdana, Helvetica, sans-serif">Or am I just getting cynical in my old age?
