If equipment is labeled for Arc-Flash with the Cal/cm^2, boundaries, and clothing what is the correct calculation to utilize, some associated in my company say that NFPA is required by code, my argument is what code requires to use NFPA over IEEE 1584? The code requirement is to label the panel if the owner wants to go the extra step and provide all the additional information, should 70E or 1584 be utilized, the code reference in a FPN 70E but nowhere does it say to use this standard? So if someone request 1584 is it in violation of the code?
