I am wondering how many arc flash labels are typically applied to a given piece of equipment.
As an example, for a motor control center which incorporates a main circuit breaker in its assembly, would there be one label on the main cb cubicle based on the arc flash energy available at the line side of the main cb, and then each bucket would have its own label based on the arc flash available at the line side of its feeder cb?
If however the motor control center did not incorporate a main circuit breaker in its assembly, would one arc flash label (placed on the main lug cover for example) suffice or is it necessary to place a label on each bucket as well?
Presumably the MCC situation would be similar to other equipment where protective devices are 'compartmentalized' (ie switchboards, fused switch distribution panels, etc)?
Lastly, for equipment where all of the bus is 'exposed' when the cover/trim is removed (for example a typical branch circuit panel having a main circuit breaker), presumably only one label is necessary based on the arc flash energy available at the line side of the main cb?
Thanks in advance for any guidance
