Can someone answer some question on arc flash labels on 480 v switchgear that is feed on both sides with a main breaker in service one at a time. label on main 1 says equipt: swgr-bus1 and the ocpd: is the utility - fuse. the other main says ocpd is gen. cb 1 Why the difference between both breakers ? Both mains have their own 3 transformers fed from same pole.
The feeder breakers are also labeled for the ocpd - gen. cb1
There are other equipment in plant fed from the feeders with labels that are labeled, equip : Mcc2 and the ocpd: swgr- fuse10. I am not sure how they got that.
Thanks for any help.
