I am reviewing an Arc Flash study and looking at NFPA70E trying to determine exactly what clothing is required for each PPE level. Here at our facility we have a 100Cal Arc Flash suit but I am trying to determine what is needed for lower IE levels such as category 2&3
Category 2 and 3 in 70E both require Arc-rated pants long sleve shirts, or coveralls rated for the required Arc levels. If I understand correctly in lieu of these items you can wear a properly rated Arc Flash suit rated for the IE levels of each category.
My question is if there is not an Arc Flash suit avalabile on site for category 2's adn 3's what type of normal cloting is acceptable? For example are jeans which is what most employees wear considered an acceptable Arc-rated long pants for either category? Is long sleve FR shirt that most employees issue to mechanics consided an Arc-Rated shirt for either category? If neither the pants or shirt I described is acceptable then must a suit or coveralls rated for the appropriate level be worn?
What about as far as headgear. It appears that all categorys except cat 0 require an Arc rated face shield. It looks like a face shield is acceptable for categorys 1 and 2 but a hood is required for category's 3&4. Is this correct? With a face shield must you have something else covering your ears and the back of your head?
One other thing I am noticing in the study results is that for some pieces of equipment the Arc Flash boundery is extremely large. In some cases the boundary is larger than the room itself and would put people outside the room who need to stay outside the Arc Flash boundary. I was curious to see how others treated these cases.
