DANIEL LAWLOR
Hi Everyone:
Would anyone know what the required or recommended PPE is for arc flash protection when working in front of a traffic signal control cabinet based on either NFPA 70E or CSA Z462? Is anyone aware of an arc flash analysis having been done for this application (traffic signal control cabinets)?
Some of the details are:
- feed is 120 VAC, single phase, usually from overhead hydro wires
- feeds are unmetered in our municipality
- breaker is rated at 30 amps, 10 kA interrupting capacity
- the incoming feed wires terminate behind a plexiglass shield
- exposed 120 vac terminal strips are present for feeding traffic signal
lights (load side wiring) when the cabinet door is open
I'm more concerned about the IMSA traffic guys who program the signal timer
which sits on the shelf above the terminal strip than the electricians who work on the wiring.
Thanks,
Dan.
Thanks,
Dan.
