All,
I am currently working on modifying an old RFP at my work in regards to having an Arc Flash Study done. One item in the RFP states:
"Lumped low voltage motor groups for MCC's shall be modeled per IEEE standards using groups less than 50HP. Low voltage motors rated more than 50-HP shall be modeled individually. Where motor list data is not available, single lumped groups may be modeled per IEEE-141 “Red Book.” "
Is this standard still applicable?
Also, is it a TOTAL number of motors equaling 50HP or just all motors under 50HPs? For instance if I have (20) 10HP motors on an MCC, would it be modeled as (4) 50HP Loads?
Thank you,
Thank you,
