I wonder if it is the one that the receptacle slides out a little breaking a set of contacts that removes the power before you actually pull the plug out they were pin and sleeve we had some of these at a structural steel plant I worked at on our motor generator welders, but they would go bad all the time and single phase the motors, we then found a pin and sleeve receptacle that had a micro switch that controlled a contactor that wouldn't energized the receptacle until the plug was seated all the way in well after the contacts in the plug made contact with the receptacles contacts, did this because even though we had a disconnect at each receptacle the welders would still unplug the welder while power was on and one time it cause a small arc flash that burned the welders hands and arms.
The ones we have where I work now are all integrated into a safety switch with a mechanical interlock that wont let you plug in or unplug the cord until the disconnect is off, I never seen one like this before working here but it works great, I believe they are from Square D.
We had an outside contractor who needed to plug in his welder and he couldn't figure out why it wouldn't go in, I got called check it out turned the disconnect off and plugged in his welder his mouth just dropped, and there was a plaque that stated that to use the receptacle you must have the disconnect off, he made the commit "How stupid" and my reply was yes burned up hands and arms are stupid when you have a disconnect right there, and told him about what happened to the other welder at the other place, I told him at 480 volts it is not safe to ever plug or unplug a load from a receptacle, I wont even do it on ranges or dryers 240 volts as I had one blow up in my hands once as two of the plugs pins pulled out and was still making contact with the receptacle when they touched together.
