I was curious to hear other's thoughts in general on application of MV Arc Resistant Switchgear? I see this offered as a solution or a customer request a lot of times based on the fact that its a more robust and safer solution without giving it much thought otherwise.
My experience with this is that the gear is obviously more expensive, has a larger footprint, and has the added challenge of having to deal with exhaust ducts for exhausting of gaes during an event.
Furthermore from an AF Hazard standpoint I don't believe the presence of Arc Rated Switchgear alone allows one to reduce Incident Energy levels and PPE requirements simply based on the AF Switchgear alone. In other words it does not change the outcome of the calculated Incident Energy levels and PPE requirements. It may reduce the risk due to its robust construction but I view this as more of belt and suspenders with the PPE requirements still based on the calculated IE levels?
If the IE is able to be reduced by other means (Maintenance mode's, relay settings, etc...) to an safe level does it warrant the application of Arc Rated gear in a lot of cases?
Just looking for opinions and past experiences here. Thanks!
