Earlier this evening I switched on the lights on my ceiling fan and heard a pop when the light bulb blew. The base of the bulb had a black mark on it as did the lighting socket. I tried to check the voltage with a Fluke meter and ended up welding the tip to the light socket base and throwing the breaker. Shouldn't the meter automatically add enough resistance in it(the meter) to prevent the arcing? I'm going to replace the lighting unit as a precaution before using it again. About a year or so ago I had a bulb in the dining room blow and actually send down a spark onto the table. Anyone else having bulb problems? Thanks.
