Are Aluminum EMT fittings compatible with conventional EMT fittings?
Installer
I've never worked with it before and I'm trying to spec out the parts for an outdoors LMR 400 antenna cable run using 2" EMT aluminum conduit.
Can anyone give me any advice on using LB legs, Compression fittings and conduit hubs with Aluminum EMT?
I apologize for starting a new thread since this is a follow up to a previous question but, I have a crew showing up the following week and my design is due in 48 hours.
Thank you in Advance
You can use die cast EMT fittings you just need to confirm the listing. These are listed for both steel and aluminum.
I didn't realize there was aluminum EMT. I thought it only came as threaded rigid.
How 'bout them apples?
