Hi i am currently designing a cart which has 3 AC powered appliances and a DC powered LED Panel
Cart can only have 2 plugs exiting the unit
I have made one circuit for the LED panel and the 2nd circuit for the AC powered appliances. If i was to plug all 3 appliances into a surge protected power strip and ensure that i am not going over the drawn current limit, am i allowed to include the UL-Listed Power strip in the design?
UL code-states that the power extensions are not intended to be a part of permanent fixture but since it will be a movable cart, it doesn't actually fall under the category of a permanent fixture...
I have to ensure that i am following the UL code, can any one please confirm if using a power strip will be an issue?
Thanks in advance.
Thanks in advance.
