In the early 1970s I lived in a mobile home that had serious electrical issues., the outlets and switches all used "push in terminals, and were intermittent. These require ~3/8" of the insulation be stripped and the bare wire inserted into a small hole on the back of the NEMA 5-15R and light switches. I moved out after a month.
I'm building a new radio desk, I'm an amateur radio operator, and went to Lowe's to pick up some NEMA 5-15R outlets and was amazed to see "push in" outlets for sale.
Needless to say I went with high quality screw type outlets but I was shocked to see the push in outlets for sale.
Does the NEC still allow them?
I'm a retired electrical engineer, not an electrician. I like the outlets that have a clamping plate, strip the wire, insert it and tighten the screw which pulls two plates together.
Just for giggles I bought a push in outlet, wired it to ha 12AWG gage extension cord and measured the voltage drop across the push and grab connection with a 1200 watt space heater. It was 5 volts versus a few millivolts on a clamping plate outlet. In addition, the push in outlet became uncomfortable warm after 10 minutes.
Are these outlets are legal, if so, why?
Thank you, these web pages have helped me explain to fellow amateur radio operators how to ensure their antenna systems met NEC requirements.
Terrence Fugate
Terrence Fugate
