michelevit
- san jose ca
I'm sheet rocking a bedroom and am adding some recessed lights while the room is in studs. I don't have access to
the attic.
I came across these simple LED lights and was wondering if they are code compliant. My main concern is how the connection can be made. Most recessed lights I have seen have some simple small metal box directly attached to it where the connection to romex can be made to the fixture using wire nuts.
Here is a link to the LED light fixture I am contemplation.
http://dx.com/p/3w-6500k-280-lumen-...-light-bulb-w-led-drive-85-265v-73822?item=88
or
http://www.ebay.com/itm/2PCS-3W-Power-LED-Recessed-Ceiling-Down-Bulb-Spot-White-Light-Lamp-85-260V-/271063386834?_trksid=p5197.m1997&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D16%26meid%3D2180309209061299956%26pid%3D100016%26prg%3D1006%26rk%3D3%26sd%3D221126138399%26
Thanks in advance. I have learned a great deal from searching and lurking throughout this great forum.
Any advice and comments are greatly appreciated.
the attic.
or
