slc410
- Madison wi
- Electrician
Is there anywhere to look to find the dimensions of RG6 coax cable, more preferably the area of RG6. For conduit fill?
Different RG6 cables? I guess im talking about the RG6 cable that transmits television signalsThere are different cables all called "RG-6". For correct info, you'll have to look it up the cable you're using with the manufacturer. Google will also lead you to some useful info (generic RG-6 is 0.332" diameter).
I agree. Outer diameter will also vary with shield type.Yep. RG6 is a (very) generic type...
Comm cables do not have to follow conduit fill charts; see 820.110 exception.
True, but you need to get the coax in without damage.
If the diameters of RG6 varies then the av available RG6 type'F' connectors could not be used in general.'F' connectors either fit or don't fit a few lung the inside conductor insulator, around the shield and then a RT lung the outside jacket insulation.Yep. RG6 is a (very) generic type, and generically, it's 0.332" OD. After that, different jacket materials (pvc, teflon, etc) may have different outside diameters; direct-burial and inside wiring types will also be different. Belden makes RG-6 type cables with outside diameters from 0.235" to at least 0.405". I'm sure that CommScope has similar variations. You'll have to look up the specific cable you're using to get an exact number.
If you don't mind being a little over, you're probably safe assuming an OD of 0.35", but that's still just an assumption.
As is being said, RG-6 will come in varying diameters largely depending upon the shielding. The skinniest will have a simple foil shield, but the better cable will have a, so-called, "quad shield" that adds substantially to the outer diameter.Different RG6 cables? I guess im talking about the RG6 cable that transmits television signals
very true. since most cables recommend no more than 25lb pull force,
Also, be very cautious about the forces used for pull. . . I don't believe you want to go much beyond 25 pounds.
So, what you are saying is there is no single RG6 standard size then. That's good to know, thanks. When I ordered RG6 connectors they come in one size which means that I have been lucky to get an 'F' connecter to fit the RG6 cable that I have.Correct but they sell connectors made for various diameters.
I use PPC F connectors or sometimes Ideal Snap n Seal. They fit all RG6.
Thanks.Most good compression connectors will fit plenum coax (thinnest) to QS. The problem with the latter is many people do not fold the braids back correctly resulting in the F connector not going on right or at all. Screw-on type fittings are way more sensitive to OD than compression types, but they are garbage imo, as are crimp-on connectors. I use PPC F connectors or sometimes Ideal Snap n Seal. They fit all RG6.
I bought some cheap no-name compression fittings once, and they did not fit the coax I was using.
Quad Shield is unnecessary in most applications. Ive noticed BB store brand cable often has mfg imperfections which results in braid problems and out of round cable, making terminating it problematic.
RG6 cable doesnt have a set OD. I just played around with some Belden Duobond 9116, which has an OD of 6.858mm or .27". That PDF I linked earlier shows 1 cable thru a 1/2" pipe, or 3 thru a 3/4". You can get 4 thru tho if it's a longer pull or has 3-4 90s, better to stick to 3.
If you happen to be doing RG59 for CCTV, or reworking old CATV that uses it, they use smaller connips the Indian insectors (F or BNC) than RG6.
