dbrooks1027
- Northern VA
I have two MM23 Arlington that I am joining together, total dimension is 39" high 17-1/2" wide. Installing a manual transfer switch next to meter. I am cutting the vinyl siding to the above dimensions. Just curious of how the rest of the community installs these products. Do you cut off the tabs and screw the bases directly into the exterior plywood? Do most electrical installers try to install the j channel or tell the customer to get a siding guy to complete the water proofing install?
