Arlington through roof plate
Epalmateer
Michigan
Does anyone use the roof plates Arlington makes that are not meant to flash under the shingles? They have putty meant to be applied to the lag bolts they have, and it has a set screw to tighten up to the riser? How are these even raintight?
Guess I'm not sure what you are asking about but to not slide it under the higher shingles seems like asking it to leak someday down the road.
