Armor Clad grounding question
idoc4u
New User
Indiana
physician
Could you please help me understand a wiring issue I'm having? I have #12 hot and neutral running from a new 20amp GE breaker through 1/2" EMT to a junction box. From the JB I have 12/2 metal clad (Armorlite with aluminum sheathing) running behind drywall (old work) to a 15amp receptacle in a metal box. If I connect the ground in the junction box to the ground screw on the receptacle, the breaker trips. If I simply cap off the ground, I have no problems. I thought you are supposed to always ground metal clad to the junction box and outlet. It seems like the metal clad sheath is acting as the ground. Thank you in advance for your thoughts and assistance!
Forum rules prohibit us from assisting a person to perform or assist others to do electrical work who are not qualified. The reason is that the forum’s owner does not want a person to get an answer to the question they asked, but not get answers to the other questions they should have asked and were unaware they needed to ask. Mike Holt Enterprises and the Moderators of this Forum do not wish to place you and your family in danger, by allowing others to give you too little information to ensure that the installation is safe.
