Always Moore
- Maryland, USA
- Private electrical inspector
The current is there even when all the breakers including the main disconnect are off. Looking for possible reasons.
As Don said in Post 2, a utility issue could be the cause. There was an issue a few years back in my neighborhood with 'stray voltage' which was determined to be the utility using SWER primary. Single Wire Earth Return that was feeding the pole mounted transformers. Basically 1 'hot', and a #6, or #4 down the pole to a ground rod at each pole.
