D Dale001289 Senior Member Location Georgia Jul 8, 2016 #1 Is there any NEC restrictions on using 300V/30A rated terminal strips with 600V rated cable if the terminal strip meets temperature requirements? This is a heat trace application, power connection kit.
ActionDave Chief Moderator Staff member Location Durango, CO, 10 h 20 min from the winged horses. Occupation Licensed Electrician Jul 10, 2016 #2 As long as everything is rated at or above the applied voltage you are good.
