Does Article 250 permit a solid corner ground on a 480 Volt Delta secondary transformer winding? In this application a 750kVA, 208V Delta to 480V Delta step-up transformer is used in a high-rise commercial office building. Its purpose is to step up the system voltage to more efficiently carry power a long distance up the high-rise building, where it is then stepped back down through a 480V Delta to 208Y/120 step-down transformer. I'm having difficulty determining whether such an application is code compliant. Should the 480V system be grounded, ungrounded or impedance grounded? All opinions are welcome. Thanks.
