Hopefully someone can clear up what's confused me for a long time. I apologize in advance if the following is unclear or rambling.
What is secondary protection for a transformer? what does it physically look like? For instance, I'll use a 125% sized primary breaker, and then secondary protection isn't required. But, for example, I'll put a 200-225A main circuit breaker in a panelboard off a 75kva xfmr, but the circuit breaker is to protect the panelboard as I understand it not the xfmr. The feeders would be indirectly protected against overcurrent by the breaker but not protected from ground faults. Also, sometimes, I'll have a fused disconnect on a secondary side of a xfmr, but again this is for the feeders and the downstream panel. How is secondary xfmr protection different, or is it? Is the fused disconnect or main circuit breaker mentioned above the secondary protection, or is it something different?
